Old Sep 22, 2009 | 10:28 AM
blackcrossfire07's Avatar
blackcrossfire07
Default Re: Classic Valve Cover Gasket
Originally Posted by tighed1
Found out my roadster has a slight leak on the front portion of the valve cover this past weekend.
Tightened the bolts a bit. No more leak.
Remember having to do this on the coupe before also.
Thanks for the tip! I did some web searching and read that you could try tightening the bolts. It is good to know it worked in your case. I will try that and be very gentle without putting too much force on it. I never noticed the smell before when I drove it everyday... so the leak must not be too bad.
