Old Sep 23, 2009 | 12:44 PM
rcompart's Avatar
rcompart
Default Re: where to buy the wiring harness
You can buy the one for the VW/Audi and switch the Red wire (+12VDC Constant) and the Yellow wire (+12VDC Ign Switched) around and make it work. Also, you may need powered antenna amplifier. Some say you don't need this but every Crossfire I've installed and aftermarket radio in has required on for same as stock reception.
