Originally Posted by gadget57
I replaced all front brake pads on a 2004 Coupe crossfire and I do not know how to reset (turn off) the "Brake Wear Indicator" light. Can anyone help me please, thank you.
You don't need to 'reset' this. Your new brake pads will be thicker and will prevent the wear indicator from be activated.
The wear sensor is the tiny bit of plastic that clips onto the pad itself. If it still lights up after changing the pads then I think I'd check to ensure it was put back together correctly.
