Originally Posted by Teck-9
How much boost can this engine withstand and how much horsepower would it put out with said amount of boost? Looking to use rear mounted turbo or twin turbo. 500 horsepower is the goal. A 500 horsepower Crossfire should be enough to drag the names of Italy's finest through the dirt.
Properly built, the M113 engine should be able to take up to 3 bar. This is equivalent to 1400hp.
Of course, this means wet sleeves, 8:1 compression pistons, new forged rods, dry sump oil pump, 1500cc, larger oil squirters, upgraded head studs, 3-layer MLS head gaskets, etc.
So the motor will last 5-6 full power runs before a complete rebuild is necessary, but you did ask.
