Originally Posted by AlanH
I'd be really worried about FODing the supercharger. For those non aviation types out there, Foreign Object Damage. At the speeds those lobes are moving in that housing, and the tight clearances inside these units, even something small would dent your wallet pretty thoroughly!
this should be a non issue. this design is mainly for use with the stock airboxes or the sl55 airboxes which both can use k&n filters. the oem setup has tubes running thru the rad support. this is a bigger upgrade and no fod issues unless you are running without filters.
