Old Sep 26, 2009 | 10:54 PM
zalsaigh's Avatar
zalsaigh
Default Re: Blower Control Runs All the Time
Originally Posted by zalsaigh
The blower control in my 04 Crossfire runs for more than 30 minutes even when the ignition key is turned off and removed. I read several threads that suggested a faulty blower control may have a tendency to be shorted out. Accordingly, I bought a used one from LKQ and when I installed it, it did the same as the original one. LKQ promised to send me a replacement on the assumption that the used one is also shorted out. I know many of the Crossfire owners have experienced a similar situation, I wonder if the fault is the blower control or the blower regulator. I am surprised at the fact that Mercedes SLK which uses the same units does not experience problems with the climate control like the Crossfire. I would appreciate the information.
I am happy to report that my blower running all the time problem is solved by replacing the blower regulator/resistors. I replaced the blower control which did not solve the problem and the vendor accepted to return the unit for refund. I bought the regulator cheaper than any one reported in the forum for only $106 with free shipping from www.AutohausAZ.com I searched under 04 Mercedes SLK either 230 or 320 rather than Crossfire. Now we know for sure, if the blower runs while everything is at the off position or the key is out of the ignition, the blower regulator/resistors is at fault.
