Old Sep 27, 2009 | 04:03 PM
SRT-6 Steve's Avatar
SRT-6 Steve
Default Re: Problem with engine after chip tuning (ECU)
Originally Posted by Welander
Thanks for all your replies. I'm going back to the store, and hopefully they can read what codes it is throwing. I think that SRT-6 Steve, was right on when he said " I gave it full throttle, the car almost died, then picks back up", that is exactly how it felt. How do I do throttle reset the easiest way, and is there a way to determine that it has been done successfully? The other thing is that since my "shakes" today on the freeway my "check engine" light has constantly been on, is there a way to reset it as well? Thanks again!
Key on but engine not running, pedal down, 5 sec, key off pedal up, wait 2 minutes.
Keep the key in for the entire time.
If this doesn't work, disconnect your neg. battery cable for 20 minutes. This will re-set the parameters in the drive-by-wire... and will reset your code. Unfortunately it will delete your pre-set radio stations, clock etc. as well...
I feel there may be something else wrong with the tune but at least this way, you can feel the process of elimination.
