Old Sep 27, 2009 | 08:01 PM
onehundred80
Default Re: n/a fuel pressure
Originally Posted by TVT_DESIGN
4 bar or 58 lbs/hr
Fuel pressure at the injectors is from 54-61 psi.(3.7-4.2 bar) about 4 bar as stated.
The ratio lbs/hr is used for the maximum injector flow through rate.
Fuel injectors rely on the volume and pressure delivered from the fuel pump as they do not create pressure themselves and the fuel pump can easily exceed 58 lbs/hr.
So the above statement is a bit misleading.
