Re: V8 Crossfire Conversion Diary
Well It now only two weeks until the swayp happens. I have been getting pretty nervous but hoping the engine will run so that i don't have to swap it back to V6. Karim (Kanzus) helped with the Key Gen which produces the DAS key that raises DAS to developer mode. I went through the process and just tested it Now when I first enter a car inDAS it gives me a warning in German which I assmume says "you are in developer mode so be carefull what you screw with. Developer mode enables you to change just about anything and is only in german as it was intended to be used in the factory to build prototypes and make adjustments to pre production cars. Eeric will be the intepreter while in Developer mode and he has also bought my other set of MB wheels for his SSB Crossfire.
