Originally Posted by ckovach
I've been running a Braille in my SLK32 for about 4 months. Not quite as cheap as the Rage Tec battery, but high quality. I didn't go with the ultra-light version (6 lb) because I wanted more amps, but this one is still only 11.5 lb and it works great:
tp://www.tirerack.com/accessories/detail.jsp?ID=28&cat=Batteries
Don't waste your time with the Braille aluminum mount kit, though. It's heavy and way overpriced. i originally ordered it then sent it back. The basic mount that comes with the battery works fine, looks good, and is much lighter. Here's the full line-up of Braille products at Tire Rack:
Tire Rack: Braille
Yeah, I was considering(and pulled the trigger on) buying a Braille battery for quite some time. I ended up getting the 17lb battery so I know it'll have enough juice for my aftermarket sub/amp.
I didn't buy from here......but this is the one I have on order.............
Braille No-Weight All Season Battery (17lb, Left Side Positive Terminal) [BR-B23 EDO Performance
