I think you have to post 1000 time to make senior but your posts should count as 50 each! Did you receive the emails I sent you? I did have a question about initial programing. I was in simulation mode and entered cars-215-CL500 and then it wants my VIN. I entered the Crossfire VIN and it was rejected. Is this becuase it is a Chrysler VIN? Or wants a VIN that applies to a CL500. If I enter the CL500 VIN and I cuasing problems for myself? Did you enter the CLK VIN or the E55 VIN in the initial Start up?
You may enter DAS with choosing car model first and not entering by VIN.
I think you have to let das read ECU first, then enter initial startup, and program ECU.
It will give you choice of engine (113K) whitch means 113=V8 K= supercharged (not in your case) etc..
I don't know how Das simulation works in details, but it's just simulation and think not real at 100%, it has limit.
When you'll swap everything and start programming ECU, be sure you'll not succeed first time, you will make many tries before engine starts.
DAS doesn't let you program something wrong, you can be sure. This program is the stongest one I ever used, it is well done.
Sometimes I have to try many times the same step before it takes effect, mayby because we use a DAS copy !
Please send me your VIN by PM i'll check it.
Karim.
