Originally Posted by jmwynne
Did anyone ever find the squeak or squeal? I have the same problem with my '05. Had it checked out but the problem cannot be found.
Here is my description. I hear the noise at low speeds only. Stepping on the brakes has no affect on the noise. However, turning the steering wheel to the left or right will make it go away momentarily.
Sure would be nice to get rid of the noise.
With my squeal, when I apply brake pressure it stops, even slight pressure. Like I have said before, I reaplacing/upgrading nearly every component of my brake system within the next week or two and will post results once I am through, especially if it affects the noise. Will check bearings as well.
John
