Re: Mystery no start issue
Ok, third time posting this. Hope you got it!
Meanwhile if the car stalls again open the hood and on the passenger side right next to the battery is a black plastic box. If you open the box (by sliding the tabs located on the top of the box) you will see a couple of circuit cards closest to the battery side and then there's a smaller black plastic case that is on the engine side of the box (furthest from the battery side.). This is the relay control module. Smack it around a little and try to restart the car. Might work, might not.
Let us know if it works.
