Old Oct 10, 2009 | 11:44 PM
amx1397
Default Re: Rear End Noise after Rear Differential Replaced under warranty
bearing check,, jack up wheel see if it moves when you pull and push top and bottom,,, side movement will not tell you because of steering,, again if u have a small amount of movement ,,the bearing could be loose or bad, jim
