Old Jan 31, 2005 | 12:52 PM
HDDP's Avatar
HDDP
Default Re: XF -- feasible track car? ???
Originally Posted by XFiring
HDDP, i looked at bergwerks site. It likes like you are getting the 'medium' treatment, but they also go all the way to extreme which is 31% higher than stock. Did you talk to them about this, what are pros and cons?
I did the math on the ratio change and based on the length of the straightaways at the tracks I usually run, max. 1800' at California Motor Speedway and much shorter at Laguna Seca, then only 1100' at Willow Springs.
I had to balance the RPM change with the fact that I still drive the car on the highway. the 3.69:1 ratio will put me at a good range for highway driving in 6th gear and still give me much more torque going through the turns at the track. A +13% change from the OEM 3.27:1 ratio.
Trust me, I debated a much steeper change and would have gone up to a 4.02:1 if I was only driving the car on the track. But then I would be running in the high 3,000 RPM range at 65 MPH on the freeway for extended periods of time, which as you know, wouldn't be too good for engine life, not to mention my gas mileage.
Also, from what I understand, the 3.69:1 differential comes from a Mercedes W123-240D and bolts right on to the car with the gears matched from the factory. The other differentials are custom built by an outside vendor. I figured I would go with the factory equipment.
