Old Oct 13, 2009 | 04:16 PM
onehundred80
Default Re: Water in trunk ??
Originally Posted by hcarter
Hey gang I need some help I'm kinda stumped I have water in the space where the tire stopleak is stored this compartment is empty and kept clean
I knoticed the water (about 1/4 full ) a week or so back and dryed it our and at that time I checked the rubber seal on the trunk and all looks fine ,,and also the rest of the entire trunk is dry no sign of mosture anywhere even under mat ,jack compartment and air pump compartment also very dry no signs of any moisture before WHAT'S WHAT
Thanks for any suggestions I'm confused
Howard.
Is it possible for the water to be coming in around the rear lights? It could just trickle across the trunk floor (boot?) and then go into the pocket in the foam tray.
Another possibility would be a leak from the wheel well as that is adjacent to the pocket directly.
