Old Oct 17, 2009 | 11:09 PM
mrwhit08's Avatar
mrwhit08
Default Re: Heated Seat Aftermarket Repair
Spensley, how are your seats working with the single pad install? It looks like you just cut the wiring and ran the single pad to the main harness.... which only had 2 wires, supposing + & -, or red and black. Simple enough if so. Afterwards everything worked as normal? ie. dual temp setting? Thanks. Both of mine are out and its getting cold so I want to go ahead and get my seats squared away. Everyone says there are 4? total per seat? I assume Lower back, bottom center, and 2 x bottom sides is this correct? If so, does the one larger pad compensate enough heat compared to 4 heating pads?
Sorry for such overload, I just want to get it right the first time, Thanks mercedez for leaving this to us.
