Old Oct 18, 2009 | 08:46 PM
green-ghost's Avatar
green-ghost
Default Re: Slashers/Calipers
Duplicolor set is a good bet but if youre budget minded you can do it for 10 bucks. First clean the calipers really good with a small wire brush and brake cleaner. When you got it clean, do it again. Spray some black bbq paint in a cup and brush it on as a primer. 2 coats. then take hi heat engine paint and brush that on top of the bbq primer. Ive done this to several cars and its a sure bet. Mine look great after 1 1/2 years. Definetly do the bbq as primer cause if the engine paint starts to flake off its a bummer.
I just put slasher stripes on this weekend. One suggestion is to really clean the area around the jack rubber cause thats where the decal ends up. A hair dryer really helps too.
