Interest in Adjustable Sway Bar End Links?
I'm in the process of putting together a set of rear sway bar end links for my car. I'm installing a larger sway bar, so I figured now would be the best time.
The stock pieces are plastic and these will be chromoly with adjustable rod ends. If there is interest we can get a GB going. These things can run anywhere from 75.00 to 200.00 or more depending on materials used.
Basically this will allow you to correct pre-load caused by lowering your car, and better dial in under/over steer. It is a basic bolt in that will not require any special tools for the install.
If there are 10 interested people we can all just split the cost of parts, not trying to turn a profit on this.
