Old Oct 25, 2009 | 09:35 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Interest in Adjustable Sway Bar End Links?
Originally Posted by waldig
Make me on the list near the top, wanna know more about bigger bar and links. Woody
I went with the HR sway for the rear. I believe it is the same size as the SRT, but solid. I just priced out a set of endlinks and they will be Heim ends that are teflon/kevlar coated on the inner bearing, cold forged SS rod, SS jam nuts, and SS reducers and bolts. The only modification that will be necessary if to open the hole on the sway bar and the chassis to 1/2" as right now it is only 1/4". This will allow for a much sturdier link and actually a less expensive one as 1/4" is an odd size.
With the materials I just purchased we are probably looking at about 170.00 a set. That of course all depends on if what I purchased will work effectively. We can save about 50.00 if we go with less expensive heims but that's not a place I want to save money.
