Re: occasional clunking noise also rumbling from rear
If the sound is loud and there is rumbling, and you have aftermarket wheels, I would check to ensure the front and rears are centered correctly. On my front 20s the hole for the hub is a little larger than the hub itself and if they are not centered perfectly, I get vibrations and humming on different surfaces to varying degrees. May not have anythiung to do with your setup, but I would check....
