Old Oct 27, 2009 | 06:55 PM
tnd's Avatar
tnd
Default Re: rough idle after fast acceleration
Originally Posted by tnd
anyone have this problem?
after a fast acceleration and coming to a stop the engine will act like it is going to stall and no response at all from the gas pedal, the engine will idle rough for a few seconds and than the rpm will go up and than back down to normal and all if fine ( this does not happen all the time )
any ideas (took to dealer and found no codes and could not duplicate the problem)
mine did the same thing, the problem was the air cleaner was not seated properly, re-seated the air cleaner and all is fine (this happened after I had the dealer change the oil, they also did not re-install the 2 air hoses properly)
