Thread: Unsafe Car
Old Feb 6, 2005 | 01:56 AM
CyberGreg's Avatar
CyberGreg
Exclamation Re: Actual TSB!!!
Okay guys... take a chill.... I found the actual TSB that caused Epyon's problem!
Originally Posted by TSB 27-012-04
TSB 27-012-04 Released Dec-04
Problem: 2004 & 2005 Chrysler Crossfire transmission gets scared
Cause: Quick deceleration or large obstacle in path of vehicle
Resolution: Reset vehicle
Note: Reassure owner that problem is unlikely to happen a second time because the automatic transmission "learns" the drivers habits and hey if he's not afraid of that big truck, then why should the car be!
Okay.. seriously it might have helped if you didn't call your car (which I might clarify is the same as my car) a piece of crap just because of one single incident.
Suggested post:
I was driving along and had to make a quick stop because of a truck blocking the road. When I put it into reverse nothing happened. I couldn't go forward or backwards. I turned the car off and restarted it and it was fine. Has anyone else had this problem?
Edit: notice the lack of POC comment.
Good luck on the forums....
