Originally Posted by Infinite
it would be interesting for someone to do a piston-valve clearance test to see just how big one could regrind the stock cams.
i would hope atleast 12mm of lift, somewhere around 270* duration
The schrick max out the lift pretty much, anything higher and you get some interference issues. If you swap over to clearanced pistons (SRT6) then you have room for a little more.
