Re: HP Cam shaft specs found
Way ahead of you guys. We have cams there now that are being ground to new specs. Mr. Elgin is going on vaca in 2 weeks, so not sure if they'll be done by them.
With the schrick cams you also get valve springs, which will be necessary with an upgraded cam. You can upgrade to the V8 springs for about 550. So you may be looking at about 1200.00 for cams, springs, and retainers, not including installation.
