Old Oct 30, 2009 | 08:22 AM
smfrycruzr's Avatar
smfrycruzr
Default Re: Pls! Hints When Buying Crossfire! New Forum User!
Hello Phillip, welcome to the forum. Most of the "Stickys" at the top of each section will answer most of the questions you have. The biggest one on the older XFires is "Rust". Check the bottom of each door, there are drain holes, if you see brown have it checked out by an autobody repair or you can do it your self by following the advice in the thread. Good luck and many smiles.
