Originally Posted by newCrossfire
the nitrous nozzle has to be within 6 in of the throttle body. it disperses as a fog so each manifold should get an even amount it should flow the same as normal air would.
Exactly! If you want the most even distribution you can go direct port and have one nozzle for every runner. This will add more complexity and cost, but you will get the best results.
