Thank you Karim, we did not install the injector. We did try a coil pack and that did not clear up the missfire on #4. We are going to try plugs and plug wires. I did see that the fuel injector was different. I will get a correct injector if needed. We noticed the MAF was a different part number and will get the correct one but for now it is not causing a code.
Latana,
One thing to consider with the V-8 engine sitting for so many years is that one of the injectors is partially clogged.
You might want to give this website a check, and see if you want to try their injector cleaning and balancing service.
WitchHunter Performance - Injector Cleaning & Flow Testing Services
Congrats on getting the engine running.
I had a feeling that eventually you would get tired of the run around, and try just wiring a relay into the starter solenoid circuit!
BC.
