Originally Posted by Mr.Troy
Hi, I've been searching in this forum for a thread that has something about the engine vibrating at stops and the Engine Check light turning on and off on it's own. I'm from Mexico and took the car to the dealer and told me that the code was a cilinder missfired but was not an active one, so they just ereased the code and that was it (no charge for it) but the car is still vibrating at idle sometimes. Does anyone has a clue about this? Thanks!
Your best bet would be to look at the simple stuff on your own, first.
If it was me, I would start by making sure the air filters were clean, and then next up would be to pull the spark plugs out one at a time and make sure each one of them was at the proper gap.
After that, I would use a timing light to see if I could figure out which cylinder it is that is misfiring. Once I found the misfiring cylinder, I would switch the ignition coil over to the adjacent cylinder to see if the missfire them follows the ignition coil, or if it stays with the cylinder.
If that doesn't change anything, I would switch the fuel injector over to the adjacent cylinder to see if the missfire them follows the fuel injector, or if it stays with the cylinder.
The results of the last test would then lead to further research.
BC.
