Re: Installed SRT-6 spring on Limited
The limited springs should be longer since they have smaller coils (lower spring rate) and they still have to support the weight of the car. So with a longer spring, the static sag due to the weight of the car will balance out the difference in length vs. spring rate.
also, the SRT-6 does weigh slightly more, due to added engine components, as well as the added weight from brakes, suspension components, etc. and the automatic transmission is a pig.
my stock limited rears measure .530 and roughly 13" tall
the srt-6 fronts i have measure between .610 and .586 (exact)
and are roughly 14" tall
