Originally Posted by Crossfire725
how can you tell if your struts are bad. i feel like my drivers rear is bad. like if u push down on each corner of the car above each wheel the drivers rear gives in more then all 3 others and you heara faint schreech. yes or no bad?
if so how much do rear struts go for? and is it a do it yourself job?
thank you
The Crossfire uses shocks, and not struts in the rear (or in the front, either). On-line sources seem to have them for under $80 (
OE Discount Parts. It looks like a straightforward job to replace them.
