Old Nov 12, 2009 | 06:37 PM
onehundred80
Default Re: NAV disk trouble
I have tried loading disk one first. Disk error comes up after a few minutes. I then tried disk 2 and it worked great until it asked for disk one, then in putting disk one in it comes up disk error after a few minutes again. I might just try removing the unit (complete power down) and let it sit for a few (drain all caps internally) and start anew with the error free disks. Maybe something is glitched in it from the first set of error prone disks I tried before switching to the laptop and getting error free disks from that system.
More to come after I try the removal and wait method (with the error free CD-R's).
Have not gotten to any "calibration" point because it does not make it through disk one (yet). I thought calibration was after the unit was set up with both disks, I was going to program a local town and drive there. Am I wrong in that assumption?
Have you got the manual? if not it is in the same thread as the disks are down loaded from.
When the systems starts up it will look for satellites, I assume yours has done that already.
It will not work until you put in the #1 disk (your area) and you go for a ride, it should just flash while it figures it all out. This is the calibration.
Loading disk#1 and #2 does nothing until you have it calibrated and you will only use disk #2 if you travel to the area covered by disk #2.
