Old Nov 12, 2009 | 09:08 PM
  #39 (permalink)
RMADERMAN's Avatar
RMADERMAN
Default Re: Lambo doors, Yes or No?
Originally Posted by Corey
I was all ready to buy these for myself as a present when I saw this post...
The way you worded that makes me have to ask, does this mean that they are NOT connected to the lower hinge mount any more?
If so, are the new hinges so beefy that they make up the difference? Seems like you would lose some of your protection if you had a wreck.
I use my XFire as my only vehicle so...
Corey, my daughter's lambo doors are custom. They were not done with a kit and they are mounted to both the upper and lower areas using the original bolts to hold the doors on the pillars. You open the door to the first stop then lift. These doors are heavy and will wear out the hydrolics every couple of years. The doors can be taken back to stock with out any major problems.
