Re: Help, not sure what to do for winter
Actually, a factor that should be taken into consideration is if you have a manual or an automatic in your car.
If you have a manual, I believe you should always put good winter tires on your car, because of the higher possibility of clutch slippage induced wheel spin on hills. The winter tires will give a manual car that extra bit of traction in bad conditions that the automatic car isn't going to need as much.
BC.
