Originally Posted by MAXIMUSQUO
The differntial will fit on the crossfire with no added work on body has the following part# A2203510405 but you will need the rear axle too, they have part#A2083500710 becuase the Crossfire rear axle will not fit! The next what you will move is the conector between rotor shaft and differntial.
regards V8 Max
Thanks V8 MAX, I just responed to your PM and am glad you enjoyed your visit to the states and the SEMA show in Las Vegas. I am just back from my first test drive in the V8 Crossfire and all I can say is HOLY $HIT!!! What a difference!! I am about to upload some pictures and hopfully my video turned out.
So the a rear end from a C55 or CLK55 will bolt right in? And we should use the 55 axles and switch the drive flange from the four bolt to the Crossfire 3 bolt to hook up the drive shat? Do you know if the C55 or CLK55 has a posi rear end? I have seen that a quaife is available for that rear end.
