Old Nov 15, 2009 | 04:32 PM
danimal's Avatar
danimal
Default Re: rough braking and loud squeal with rotex golds
Originally Posted by Infinite
they are a race pad, rough braking and squealing are normal. The pads are metallic, not organic. Get used to it or get new pads.
Not true at all.
white04XF, what rotors did you get? As far as the rotex pads, did you use anti-squeal on the back of the pads and did you do a proper bedding-in of the pads?
I have had rotex pads on mine for over 32K and have never had the first squeal or grabbing brakes. They are just as good, if not a little better, than the factory pads without the dust.
I would recommend taking them out, using the anti-squeal as directed, and then bed them in using whatever method you feel comfortable doing. A google search will give you any number of methods to bed your pads. It works.
