Old Nov 16, 2009 | 04:59 PM
onehundred80
Default Re: Is It Possible to Swap Sat Nav From One Roadster To Another???
The items you need and installation instructions are shown on the following .pdf file.
The antenna adapter # GRE40EU10.
The last item is an antenna from Germany that works well. But I would remove the one you have, you can see where it is from the instruction sheet.
The two wires that you need require a connector pin on the end that snaps into the connector that plugs into the head unit. PM me if you want these.
http://www.majormotorshotrods.com/_d...av_install.pdf
GPS-ANTENNE-WICLIC-SONY-PIONEER-JVC-MERCEDES-BECKER (Not working but this is the description)
Splicing the wires to the wires coming from the amplifier will be the hardest job, the actual job is 2 hour max. easy for me to say as bluecoupe did mine. You will of course need the two keys to remove the radio and a trim stick to remove the trim around the radio.
For the record my car is a 2004 and it came completely wired for the navigation unit except for the antenna of course. This was strange as nav was not an option that year, here anyway.
