Well, things are coming together albeit slowly. Little by little I am making some progress despite the set backs of getting sick then hurting my back. That said, I look for things to start picking up over the next week or so. For now, I do have a pic to share.
This is my newly designed idler pulley and mounting bolt. I hope to have it in my hands by the end of the week and installed on the car this weekend. I then want to put some miles on it. It should be more than rock solid!
Next up:
Design and prototype the support bracket for relocating the Coolant Reservoir
Design and prototype the Rotrex bracket and belt tensioner
Design and prototype the front mount HE brackets
Design and prototype the IC water pump mounting bracket
Design and prototype the IC mounting brackets
Once I get past these two hurdles I can worry about installing the injectors and wiring up the electronics:
AEM
Knock Sensor to SPD input
SPD - window mount with OBD-II cable in dash
Wire in my Radar Detector
Then finally move on to the IC plumbing and ancillary support systems!
