My Zeitronix connection wire for the lap top plug in connection is hidden in the removable dash pannel you see when the passenger door is opened. The same pannel that houses the passenger air bag cut off. The two large plastic factory screws can be turned with a penny. Have you noticed the data logging when our SRT automatic's shift at WOT? You can keep the petal to the floor,but when our transmissions shift,the computer cuts the TPS way back during gear shift then to the floor again without you knowing. Maybe to keep the engine from over revving during shift,to help keep the tires from spinning so bad going into second or just for the Mercedes smooth shift??
It will also verify what Rob's has been warning us about concerning the 185 crank pulley.
It will run dangerously lean at WOT. Where's our fuel upgrade Rob???? Squirrel Crusher
Fuel problems were solved along time ago on our cars.
