re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
tighed1 your info on the relay board is great, Thanks This board also contains a relay for the secondary air injection system correct? I'll have to take mine out this winter and check for the loose solder as I keep getting that MIL code for that system. The pump runs and I've changed the check valve and it ( the Mil ) comes and goes so when I can have it down for awhile I'll remove the relay assembly.
