Old Nov 21, 2009 | 07:04 PM
harbor's Avatar
harbor
Default Re: Manual Transmission Fluid: No service is required???
John - Did the diff at 12K out of **** retentive maintenance issues plus wear & tear concerns of trying to keep up with IamFink2 at the past two Dragons and keeping pace with you & Molly at the '09 Woodward Dream Cruise.
Just had the factory techs (not dealer) do the double-wrench service last week. Car is running sweet!
Freezing? Had the top down last week-end and temps hit upper 50s today with full sunshine . May go water-skiing this Thanksgiving thanks to global warming! I'm fairly certain it won't even snow in Michigan this winter.
Jim, I knew you did the tranny fluid, something I need to do as well. But you have also done the diff? What is the reason behind this, do they use a sub par product from the factory or was it routine maintenance? Thanks, hope you are not freezing too bad up there.
