beautiful pictures mike, thank you! yes that seems to be the preferred way into the cabin instead of using the rubber grommet under the battery tray. do you mind if i use some of those pictures to add into our writeup?
i have our zt2 brain in the same elastic pocket there on the pass side, makes it very easy to access the port to plug in different displays.
built on the bench right now, been playing with it today, i think its ready to go onto the car as soon as the last relay arrives. and here is the best part..... it will be run by the zt-2 brain that you guys already have
im very excited with it.
please post up a datalog
Dyno tuned by LET with 11.7 AFR straight across the board contact Jerry or Wayne. They saved the file.
