Re: Do you like your light up door guards?
just use your your electric controls on the seat to push it all the way up and then forwad, unscrew the plastic edging on the door jam, and wire bundle is right there! I just used those plastic 3M wire splices (gotta love them) on the wires. I cheated a little getting the other wire to the drivers side. I only pulled back the passenger side carpet. I did the ol metal clothes hanger mod with the wire taped to the end and went right under the console behind the carpet and push it to the bottom edge of carpet behind the drivers seat. Once you get it there, you can run the wire under the edge of the carpet at the very bottom to the drivers sill. The carpet is stiff down there, but with a little pulling and pushing it fits in there like a champ! Cant see it al all all the way to the sill! Good luck!
