Originally Posted by crossfirefrank
He is right about the bundle of wires, I gave up after 20 minutes of searching and just pulled the trim off the passenger side pillar. I found the dome light wire in the pillar and tapped into it. Took me about ten minutes to route the wire up the pillar and splice it. Save yourself the headache and splice into it at the pillar location.
Can you add a little more info to the pillow wire. Do you take the pillow off? Is there screws, and is the only one wire in it and is it the correct one? Than you need to ground the other 2 brown wires on the light.
In the instructions, I posted above, it shows the correct colored wires to tap into at the harness. It was brown and gray left side to brown of lights which should be a ground. Brown pink right side to brown of lights which should be a ground and black yellow white to red of lights which should be positive.
