Old Nov 23, 2009 | 02:44 PM
goodgenes79's Avatar
goodgenes79
Default Re: Coolant/Antifreeze question
Originally Posted by amx1397
do you have any pic of both or can you tell us the differance thanks jim
I wish I had thought to take a pic of them next to each other. The E55 H/E is roughly 6in longer and a 1/2in wider. A little modding and fits where stock goes with stock air dam.
Originally Posted by waldig
If your peak is rated with Aluminum then your ok, my big push is to get people to consider using a radiator flush before refilliing.
I got out massive gunk and ran it out into a cloth to catch and see what was flushed out. The system ran better after that, and that was before I made up the supercooler. Back then I was running the stock H/E and had 12,000 miles as a second owner from a dealership.
If you care to look back in my many posts, there are photos of the stuff and all that, enjoy. Woody
can you explain how you ran your flush out? the radiator has that small red screw plug and doubtful that gunk will pass. Did you just use the intercooler pump to run it all out? and if not, could you? I ousl like to do a good flush, but want to make sure I have everything out from the heater, engine, and intercooler. Sorry to sound so ignorant.
