Re: Coolant/Antifreeze question
jason what woody told me was to use the prestone flush kit and fill the rad. run the engine and remove the red plug and drain. then run clean water thru and flush again then refill with hoat compliant coolant and distilled water. m/b coolant mopar coolant or the zerex g05
my systems are separated so i dont know if flushing will affect the i/c pump in any negative way
