Couple people have tried, nobody has done it successfully without either blowing up their motor or going a different route. The compression ratio is too high on the NA motor and the SC makes too much boost so these two things you will need to overcome along with getting the right amount of fuel into the mix with the added air.
There is a guy doing a rotrex SC upgrade that looks about as promising as anything. Check out the thread
here.
