Old Nov 27, 2009 | 12:42 PM
distantpulse's Avatar
distantpulse
Default Re: Few question about my srt-6
Originally Posted by velociabstract
I have Eibachs on my SRT-6. On the back you can get 1 1/2 inches of drop when combined with the shortest spring pad with no rubbing. On the front I used the tallest spring pad which lowered the front only 1/2 inch and have very slight rubbing. My tires are 4mm taller than stock and I have 10 mm spacers on the front so you need to consider that as well. As far as if I like the Eibachs ...... not for how I use my car. They make the car look great but the performance on the SRT-6 is inferior to the stock springs, at least with Koni shocks. So, if you want Eibachs for the looks I give them thumbs up. If you want them for better handling at the limit, thumbs down. For day to day situations they get a thumbs up from me as well. How you drive will make all the difference as to how much you like them or how much you wasted your mod money. IMO
Les
Thanks Les. I am going to be lowering mine at some point in the near future and this is good info to me. I will probably cut the original springs down and install the koni's.
