Old Nov 28, 2009 | 03:44 PM
  #55 (permalink)
tighed1's Avatar
tighed1
Default re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by Roxyfire
Great write up tighed1. Now, after the repair, I got a different problem, I can't shut off the engine. I was able to pull out the key and the car was still able to drive [put the car in reverse and pull out of drive way, drove it around the block and come back]. After pulling the neg/pos terminal of the battery and its still running [off of the alternator]. So what I had to do was pull the RCM which would shut it off. I'm assuming its my Ignition is the problem and not the RCM. I also did the "Me horny" mod also. I checked my soldering for that mod and making sure its not overlapping.
After you did the RCM Horny mod and installed the RCM and reconnected the battery, did you hear any relays clicking or fans running (with the key out of the car)?
If so you may not have cut your solder runs deep enough.
DON"T go spending $$$ on a new RCM if your car was fine before you modded. You can always jumper accross the cuts to make your car un-Horny. Or send it to me and I'll check it for ya.
DJ
