Old Nov 28, 2009 | 08:12 PM
onehundred80
Default Re: Is this fuel filter for our car ACDELCO Part # GF893 {#89034698}??
You should state that before changing the filter they should release the pressure and use some of the gas in the line as stated in the shop manual. We wouldn't want to lose a Crossfire and driver in a ball of flame.
The no smoking rule applies as well.
See shop manual for further details and pictures.
From the Shop Manual
1. Remove the fuel filler tube cap.
2. Remove the fuel pump fuse from the relay control module (3) located next to the PCM.
3. Start and run engine until it stalls.
4. Attempt restarting engine until it will no longer run.
5. Turn ignition key to OFF position.
6. Return the fuel pump fuse to the relay control module.
7. One or more Diagnostic Trouble Codes may have been stored in PCM memory due to fuel pump fuse removal.
The DRB III
T scan tool must be used to erase a DTC.
Note: Place a shop towel around fuel lines to catch any excess fuel during disassembly.
4. Remove the fuel filter/pressure regulator degassing line (1).
5. Remove the fuel rail supply line (3) at the fuel filter/pressure
regulator.
6. Remove the fuel delivery hose.
7. Remove the fuel return hose at the fuel filter/pressure regulator.
8. Remove the clamp retaining screw and remove the fuel filter/pressure regulator.
